timing belt
Old Nov 15, 2006 | 07:57 PM
fwj8186's Avatar
Default timing belt
Trying to check honesty of my auto mechanic. Had new radiator put in yesterday (1990 mazda mpv) Today timing belt broke. Are the two connected in some way, ie. do you have to remove the timing belt to put in new radiator?Sure would appreciate some help.Thanks
Old Nov 15, 2006 | 08:49 PM
bkey71's Avatar
Default RE: timing belt
The timing belt is in no way related to replacement of the radiator. It would be very difficult to make the connection. The timing belt is behind covers that would have to be removed to even inspect it. The timing belt should be replaced every 90K.
Old Nov 15, 2006 | 10:30 PM
dan908's Avatar
No way unless you also had the water pump removed. And even then I don't know that an MPV has the water pump in the timing. But if you just had radiator replaced, no relation.
kinni420
Jan 28, 2013 03:08 AM
mazda99
Aug 13, 2008 04:18 AM
homeflash
Apr 4, 2008 11:55 AM
tidyclio
Sep 19, 2004 01:36 PM
