Tail and dash lights not working
Old Jan 1, 2011 | 05:15 PM
SanCarlos_Tribute's Avatar
Default Tail and dash lights not working
Can someone please help?
My tail and dashlights do not work.
1. brake lights work
2. fuse checks ok
3. bulbs check ok
4. head lights work
5. brake light socket gets voltage when brake pedal is engaged
6. tail light socket does not get voltage with head lights are turned on.
Do I change any of the components in the power distribution box?
Old Jan 3, 2011 | 10:02 PM
Ironwindow's Avatar
This is going to sound real dumb, but if the stereo is not working, check the stereo fuse. depending what year/model you have, your dash lights, tail lights, and stereo are on the same fuse.
if it is not the stereo, it could be the multiswitch on the steering column. it might not be operating correctly, therefore not sending the signal to turn the lights on.
Old Jan 20, 2011 | 09:13 AM
tonylmy's Avatar
Default My tail and dashlights do not work.
2. fuse checks ok
3. bulbs check ok
4. head lights work
HI, I'm having the same problem, seems like it's common but any solutions anyone? Checked the fuse all ok. Previously before it went out, I used to get intermittent when I go over a bump on the road. But after a few bumps, it totally gone. Any help is appreciated
Old Jan 21, 2011 | 10:19 AM
My apologies for not responding to Ironwindow. We had extensive water leakage from the sun roof and it was the multi-switch in the steering column as he suggested. Replaced it and everything is working fine.
Old Feb 28, 2011 | 08:19 PM
rayd9668's Avatar
Default Same problem:Tribute
2001 Tribute: Dashboard lights and tail lights out. Fuses look good. Stereo works. I just changed the column lights switch/turn signal wand. It did not resolve the problem. At first, the left turn signal would not blink, then it did, and now no dashboard, or tail lights. What is next for repair? I need some help.
Ransack
Jun 23, 2022 09:43 PM
Auburngal
Jan 17, 2012 08:52 AM
jpaschal21
Jun 17, 2009 06:56 PM
anthonytsi
Nov 12, 2008 04:37 PM
Kailem
Sep 10, 2007 05:10 PM
