Stalling when hot
Old Apr 15, 2007 | 05:43 PM
gblvdgirl's Avatar
Default RE: Stalling when hot
I pulled the IAC valve and cleaned it with choke cleaner, No luck. What about the fuel pump relay? Could that be overheating and shutting down causing me not to get fuel. It does feel like I'm running out of fuel before it stalls.
Old Apr 16, 2007 | 08:33 PM
babyhuey's Avatar
Have you been able to determine if you are loosing spark or fuel pressure after it stalls and will not start untill cools down for 5 minutes???
The fuel pump relay is in the underdash fuse/relay box and is labeled CIRCUIT on the location diagram imprinted onto the under side of the box cover.
Old Apr 19, 2007 | 05:19 PM
gblvdgirl's Avatar
Don't know if it's spark or fuel loss. I replaced the fuel pump relay. That hasn't helped either.It's very frustrating to me. I've spent over $500 on this car in the 2 months thatI've had it.I'm stumped. Thanks for all the replies.
Old May 2, 2007 | 06:35 PM
gblvdgirl's Avatar
It's now overheating! We pulled the thermastat and that hasn't helped. Now what? It's still overheating.
Old May 2, 2007 | 10:06 PM
babyhuey's Avatar
Are the cooling fans coming on? If they are but is still overheating then, disconnect the fan connectors so you can reach a hand down in there without possibility of them coming on. Let engine run untill it just begins to overheat and then reach down and carefullyplace your hand on as much of the radiator surface as you can thru the fans. Carefull as it may be very hot. Radiator surface should be hot across the entire surface. Lower area should be slightly cooler but probably will not be able to feel this with just your hand. Non-contact thermometer works great for this. If you feel cool or cold areas then your radiator is restricted. If top tank and entire radiator is cold then could still be a very badly restricted radiator but would more suspect that hot coolant is not being pumped to the radiator from a possible failed water pump of belt missing.
Old May 4, 2007 | 09:54 PM
gblvdgirl's Avatar
The fans are working. We also flushed the fluid and put new in.We are going to try the the water pump. Do you think that could have been why the car was stalling when it was getting hot?
Old May 7, 2007 | 11:21 PM
gblvdgirl's Avatar
Turns out, the alternator belt that I just had replaced broke. What would cause that?
Old Dec 30, 2018 | 06:40 AM
cazoom's Avatar
Default Stalling when hot then restart after 5 minutes
Did you find an answer to the stalling when hot? I have the same issue in my 323 Astina 2000 manual. I have replaced the MAF, fuel pump, fuel filter and the crank angle sensor. Need help as its intermittent and it will start after 5 minutes.
Old Jan 29, 2019 | 02:52 AM
Robert Evans's Avatar
Default Rob
I’m interested if anyone has solved this problem. My daughters Mazda Astina has the same intermittent problem with stalling when hot and restarting after 5-10 minutes. Replaced the fuel pump, crank sensor, one coil pack which was supposedly faulty. It’s back with the auto electrician who is stumped as well. Love to hear any advice. Thanks
Old Jan 29, 2019 | 02:53 AM
cazoom's Avatar
I found the issue it was the cam sensor. It hasn't had a problem since. Hope this helps you
andrewlwilson
Aug 7, 2008 10:48 PM
marsjuh
Nov 3, 2005 11:25 PM
my85626
Sep 20, 2005 02:24 PM
old929guy
Jun 12, 2005 04:18 AM
scott
Apr 30, 2004 11:23 PM
