oil in airbox
Old Aug 22, 2012 | 09:08 AM
Originally Posted by 96 prtege
its going threw about half a liter every 100 miles i just dont understand this?
That's a lot. If it's not leaking, it's burning. You could have bad valve seals or worn piston rings. Compression test (dry and wet) may verify this.
If you had a catch can you would be emptying it a lot!
Old Aug 22, 2012 | 09:14 AM
96 prtege's Avatar
yea i just didnt wanna do the rebuild on it aint got the time to change piston rings valve seal an rod bearing i have all those parts sitting in the car brand new not even open them yet bc i know its alot of work
Old Aug 22, 2012 | 12:33 PM
MazdaTirol's Avatar
How much smoke/air comes out of the oil filler hole when you take the cap off with the engine running?
Old Aug 22, 2012 | 01:29 PM
96 prtege's Avatar
no oil visable
while its idle only when driving the car
Old Aug 22, 2012 | 02:29 PM
Kevinkpk's Avatar
This is being asked as to determine the amount of blowby into the crankcase.
Old Aug 22, 2012 | 02:55 PM
96 prtege's Avatar
when idleing or when i mess with the throttle?
Old Aug 22, 2012 | 03:30 PM
MazdaTirol's Avatar
Just idle should be fine, this gives you an idea how bad the rings are, if your getting ALOT of smoke/air (blowby) your rings have pretty much had it. Do this on a warm engine and not a cold one though, cold pistons leak much more than hot ones.
RJB_M6
Nov 7, 2018 06:02 AM
beebbop
Dec 14, 2012 08:45 AM
unknown
Jul 20, 2010 03:54 PM
Wombat80
Nov 9, 2009 02:50 AM
Carlb328
Oct 29, 2009 02:41 PM
