n it need so me air conditioner help
Old Apr 15, 2006 | 12:19 PM
dannavajo's Avatar
Default n it need so me air conditioner help
I own a mazda navajo and the air conditioner went out on it. is fluid tank is charged allready just wont pump any cold air out any advice?
dan
Old Apr 15, 2006 | 11:39 PM
bkey71's Avatar
Default RE: n it need so me air conditioner help
The first thing that needs to be done is to get a set of A/C gauges on it to see pressures. If the compressor is coming on or cycling there should be a pressure change. It is usually ~30 on the low side and ~190 on the high side while running and the A/C on. This will also help to determine if charge is correct. Both pressures should be equal with the A/C off. And usually when the charge is correct the pressure will equal the outside temp as a starting point. Example: 90 deg outside = 90 psi in the system.
kandr
May 2, 2022 07:03 PM
anush_avan
Apr 18, 2009 11:58 PM
ZOOMZOOMZOOM1
10
May 30, 2007 02:02 PM
Falcon
Sep 20, 2006 11:15 PM
depfer1
Jun 2, 2006 05:12 PM
