Mazda 3 power steering noise
Old Apr 6, 2012 | 06:43 AM
chips's Avatar
Default Mazda 3 power steering noise
2004 Mazda 3 Maxx has a noise (grinding/crunching) coming from left hand side of the car which occurs when the steering wheel is turned either left or right. Can not feel any abnormality when holding any of the steering parts under the carwhenthe steering is being operated. Could this be either a loose belt or pump problem.
Cheers
chips
Old Apr 6, 2012 | 09:13 AM
shipo's Avatar
Cheers
chips
Sounds more like a CV joint than anything else.
Old Apr 8, 2012 | 06:47 AM
Mazda guru's Avatar
Hi, does the noise happen when the car is stationary or moving?
If stationary, open bonnet, and locate the shock absorber/coil spring top mount then touch the area whilst someone else operates the steering to replicate the noise. You may be able to 'feel' the noise this way. These Mazda's were prone to have noisy top shock absorber mounts/bearings that groaned or became notchy when turning.
There are genuine modified parts available at your local Mazda Dealer.
Hope this helps!
Woxy
Jan 1, 2014 07:54 AM
ScottSXT
Mar 5, 2013 09:47 AM
fflt765
May 25, 2012 12:52 PM
Mazmart Trini
Mar 15, 2012 09:27 AM
imurphy
Sep 4, 2010 12:02 PM
