Mazda 3 headlight help!!
Does anyone know how to correctly change the passenger side headlight of a 04 Mazda 3? I did it once before and struggled for over an hour. Now its time to change it again and I can't get it for the life of me. I read posts online of people taking off the front bumper... Is that what they do in the shop? Or am I right in trying to manipulate the retaining clip without taking anything apart?
HELP!
HELP!
Definitely not necessary to remove the bumper. The washer filler and power steering resevoir are a bit in the way for good access but is still possible to replace in the car. The metal clip is released by pushing the upper part towards front of car slightly then upwards. Spring clip should then pivot out of the way towards outside of car. Make not of how the bulb is positioned when removing. You will notice on the bulb socket there is a flatened side with a little protrusion in the middle (see pic below). This protrusion needs to be placed in the 11 oclock position as if you were sitting in the drivers seat. There are two alignment tabs on the headlight body assembly that this little protrusion will fit into. Also be very carefull not to touch the glass of the bulb as the oils on your fingers will cause it to overheat and greatly shorten lifespan.
[IMG]local://upfiles/1377/640B3B9BFDEA46D0882BC3E7CE5BB530.jpg[/IMG]
gregbeyer
Feb 10, 2014 07:59 AM
