Mazda 3 2006 Low Beam Headlight Issue
Old Oct 4, 2014 | 10:11 AM
General_T001's Avatar
Default Mazda 3 2006 Low Beam Headlight Issue
Hi,
Both low beams stopped working the other night. So far I have done the following:
  • checked the 15 amp fuses and they are both good;
  • metered the plugins and they show 12v DC;
  • confirmed that the bulbs are good
So I am stumped. The next thing I guess is a relay? But I am not sure which one is for the headlights (there is a 40Amp one which says "HEAD"). Also, if I am getting 12v at the plugin and I am plugging the bulbs directly into this plugin - shouldn't they light up? They don't and I am guessing that the draw caused by the bulbs isn't being allowed due to a bad relay?
Does this sound likely or am I totally off base?
Thanks
Old Oct 4, 2014 | 09:30 PM
Have you both 12+ & a earth at the bulb socket?
Old Oct 5, 2014 | 10:33 AM
hixx's Avatar
90% of the time both headlights quit working it is the bulbs. If not the bulbs then i would suspect the switch. That is assuming the fuses and relays check good. A test light and wiring diagram will sort it out pretty quick.
Old Oct 5, 2014 | 11:55 AM
Hi,
Thank you for the replies. I found out the problem. It was a combination of a burnt out bulb on the passenger side and a faulty plug on the drivers side.
Still surprised I was reading 12v DC on the drivers side from that bad plug - but it wouldn't power the bulb when connected. Ah well, problem solved at least.
Thank Again
Motorman37
Aug 8, 2017 09:14 PM
thc888
Jan 15, 2012 08:11 PM
pkepneriv
Dec 9, 2010 09:34 AM
talkshow
Nov 15, 2009 05:16 PM
mazda guy
Apr 27, 2009 07:48 AM
