Mazda 3 2006 Low Beam Headlight Issue
Hi,
Both low beams stopped working the other night. So far I have done the following:
Does this sound likely or am I totally off base? Thanks |
Have you both 12+ & a earth at the bulb socket?
90% of the time both headlights quit working it is the bulbs. If not the bulbs then i would suspect the switch. That is assuming the fuses and relays check good. A test light and wiring diagram will sort it out pretty quick.
Hi,
Thank you for the replies. I found out the problem. It was a combination of a burnt out bulb on the passenger side and a faulty plug on the drivers side. Still surprised I was reading 12v DC on the drivers side from that bad plug - but it wouldn't power the bulb when connected. Ah well, problem solved at least. Thank Again |
