fuel tank problem 2010 CX7
Old Apr 20, 2024 | 11:45 AM
DONS's Avatar
Default fuel tank problem 2010 CX7
Fuel gage reads empty so I added 2 gal of gas ,vehicle ran 5 minutes and it ran out of gas,so I added 6 gal of gas ran about 8 minutes and gage reads empty and ran out gas ,is the gas going to the other side of the tank
Old Apr 20, 2024 | 11:58 AM
You have a couple or more things that needs to be checked.
First go to the ODB diagnostic connector with a scan gauge (please don't use a blue tooth scanner) and see if there are any pending DTC. Then check the monitors.
I am sure you are going to find a DTC that might clue you in on what is going on.
Otherwise you are going to be hit and missing guessing the problem.
Old Apr 20, 2024 | 12:41 PM
DONS's Avatar
No codes ,fuel pressure is ok ,have replaced the high pressure fuel pump and the fuel pump in the tank,starts and runs fine but goes thru 2 gallons of gas in less then 3 minutes
Kevcules
Sep 14, 2022 11:19 AM
suzukiracingbr
Mar 9, 2011 10:22 AM
mzd3_stratblu
Oct 13, 2007 07:54 PM
tmyers
Oct 26, 2006 09:13 AM
Gloria
Aug 17, 2006 02:25 AM
