DPF Service Indicator Resetting?
Old Dec 19, 2018 | 02:47 AM
  #61
Mazda (6)'s Avatar
Default Dpf Light Flashing and EML on! NOW FIXED WITH FORSCAN!
Hi All,
First of all thank you for your replies they have been very helpful. I now have the car fixed and boy it is a beast in comparison to limp mode! Here's how I did it...
As suggested I bought an obd scanner from eBay for £17 and returned the old one (cheap standard one from euro car parts not a full elm327) which cost me the same but didn't work at all! The new one took a few days to arrive but it was the modded one with the Ms/hs can switch. Here's the link to the one I purchased....
https://www.ebay.co.uk/itm/Forscan-ELM327-WIFI-Wireless-Scanner-OBD2-OBDII-Diagnostic-Tool-With-Switch/222982171730?pageci=66e2c0a4-edee-4607-b534-fefd69b4992f
It is the WiFi one.
I plugged in and after a bit of messing about with the switch and WiFi connection settings it popped up asking me if my car was left or right hand drive. Success as this means it's working and you can access the ecu. Let it do its thing and then read the dtc codes and sure enough it had the same codes as the rubbish scanner did. Followed these you tube instructions to reset the codes and oil change, calibration and dpf reset etc as it had a brand new dpf so no need to force regenerate and around 10 minutes later walla no more eml light and dpf light permanently off! Took her for a spin and wow it is like night and day. Pulls like she should and mpg are steadily increasing now I'm driving a bit more conservative after a few days. Also I must have driven around 600 miles if not more without the recurrence of the dpf or eml light! So all in all I have saved over £2500 in repairs with mazda by getting a dpf for £300 and a proper obd for £17! Here are the links to a few very helpful YouTube videos I watched to reset the above...
https://youtu.be/t0dKE_--DEo
https://youtu.be/z8Mj-l2x8Ac
https://youtu.be/gYyUO2LVpKU
https://youtu.be/xCBvNTrU4rU
Also when I refitted my cleaned egr valve and hose back my car was making a whirring sound on acceleration only so I went back and tightened all the nuts and bolts to make sure it wasn't a vacuum leak or bad gasket and sure enough I hadn't torqued one of the nuts down enough so as soon as I had tightened it took it for a spin and no more whirring sounds. Runs like she's new!
Thanks and I hope this helps you Guy's too!
Old Jan 14, 2019 | 02:53 PM
  #62
HenrikLyholm's Avatar
Hi Groves
Just to be sure, I assume you remove the wire after you turn the ignition off and before turning the engine back on? Did I understand that right?
Old Feb 2, 2019 | 01:42 AM
  #63
Mazda (6)'s Avatar
Originally Posted by Mazda (6)
Hi All,
It is the WiFi one.
Quick update: I have now driven a further 2500 miles and all is well except for a brief occurrence of the dpf and EML light coming on. For some reason I was in the way home and been in long motorway drive to and from home. The dpf light came on solid and so I put my foot down but then a few minutes later the light flashing and EML came on, so limped home and thought to myself here we go again. When I parked up I got the laptop out and forscan and it showed dpf was around 12g/l approx. This was the highest I had seen it as it is only usually 4 g/l or lower as I had been checking every few days. So I performed a manual forced regen which took an hour and once done all was back to normal. Cleared codes and reset etc and since then the problem hasn't reoccurred and I have completed a few more thousand miles! What I did though was to get an older phone and paid for forscan lite so I could monitor the levels etc whilst driving. What I have found is that regen occurs between 80-120 miles from last regen and this is subject to how you drive and how quick the filter gets to around the 4 g/l mark usually a bit over. What happens is the regen says off until it starts regenerating and then says on and you can see the g/left counter going down towards zero! Great stuff as I can now know exactly when I am in regen and can drive accordingly to make sure the process is completed. If for example a regen occurs in a town then I can drive in slightly higher rev but as long as it's around the 1700-2500 rpm then regeneration is successful! Also if you stop or slow down too much regeneration will say off and as soon as you start driving passed the 2000 rpm mark regeneration will start again until complete. So if any one is having problems like this then get an old phone and hook it up to the obd and you can at least keep an eye on this issue. I have now completed 36 regenerations since I reset the counter back when I changed the dpf filter! As to what caused the dpf flashing and EML I do not know but at least I can now monitor it and make sure regeneration is completing successfully! Oh and I have saved more money again by not needing to go to he dealership!
Old Feb 3, 2019 | 04:00 PM
  #64
smartguy69's Avatar
If only Mazda had put a button on the dash that lit up and said "hit me now and drive until the light goes out". That's the proper way to do a regeneration. The Mazda 6 was a great car let down heavily by its dpf regeneration system or should I say failure of its regeneration system. Any car that has a rising oil level, i.e dilute oil with diesel is a bad idea. The car injects diesel on the exhaust cycle to raise the temperature to burn the soot and not all of that diesel gets burnt. It ends up in the sump. Don't check that X mark on the dipstick often enough and the engine will eat it's own oil which if you dont' realise it's doing it, will be total engine failure. Renault had the same system on their Laguna and some other manufacturers did too. I did an oil change on mine when it hit the X mark and took nearly 7 litres of "oil" out of it. That's nearly 3 litres of diesel mixed with 4.2 litres of oil. I had lots of trouble with mine before finally sorting it once and for all. The problem with the Mazda is if it fails the regeneration it does what yours did with the new dpf and then its a trip to the garage. There are a few parameters that a Mazda needs before it can do a regeneration but the one thing the clever ECU never knows is where you are, where you are going and when you are going to stop. 4 times on mine I had the dpf light come on flashing AFTER doing a long journey. One of these journeys was on the way back from Scotland and bear in mind when the engine is hot it shouldn't be creating hardly any soot so shouldn't need regeneration. Bad timing I guess but driving 650 miles to Austria with a flashing eml light, being overtaken by Renualt Twingos uphill is no fun. And the fault, it had failed it's last regeneration said the German mechanic. So if something fails then try again, I was on a motorway FFS. I think I am better placed when a regeneration should occur and not the car. The car just needs to tell me but this version of the Mazda engine put a lot of people off Mazda including dealers. I got my car for a song because I wasn't aware of the issues. It's a real shame because the 6 was one of the best cars I have ever owned and just got rid last week after 7 years. The best of those years though was after having the dpf deleted knowing it was never going to let me down again and something I should have done in year one of owning the car but didn't because I know it's there for a good reason. In this case at the expense of the user. It got to a point where my wife was reluctant to go anywhere far in the car in case it let us down. Least with all the running about in limp mode it prolonged the life of the turbo lol.
What you have rigged up on yours is amazing. After my Austria trip with car repaired over there my car performed very well but felt the car was regenerating too much. I found again pulling out of a service station in Holland the light came on and its hard to keep you foot down when it's busy traffic. 3,000 rpm in 3rd for 10 minutes sorted it and it was ok for a while when I got back to the UK. Trip to Centre Parks saw light come on on the A1, doing approx 70mph in 5th gear. Dropped it to 4th, floored it and then light starts flashing and then limped the last 10 miles. This time though I had Forscan, with modded EML and laptop with Delphi150. This time the car was not going to beat me but it did and 4 days later limped all the way home. A garage I knew was testing some new diagnostic software and used my car as a guinea pig. No fix = no charge. He couldn't fix it and thought enough is enough and had the bloody thing deleted for good but that was after buying a proper ford / mazda VCM and using Mazda IDS software. It was a waste of money as Forscan is all you need. It was the oxygen or CO2 sensor which the dpf delete guy found. The one that's bolted to the bulkhead. If you have issues with yours try that first along with the main wiring in the fusebox. The reason mine had failed regeneration when going to Austria could have been down to some of the terminals getting corroded. It's the main wiring to the bottom left in the fuse box under the bonnet. Check it before it lets you down.
Good luck with your Mazda and as for me I now have a Ford Kuga. Oh damn it's a diesel lol. DPF not being deleted on this car and if I clog it up I will have it either washed out or replaced as they are quite cheap as are the Oxygen sensor.
Old Oct 1, 2025 | 04:39 AM
  #65
Driventodistraction's Avatar
Default Dpf light rubbish
[QUOTE=Eagle3561;166243
Just had to become a member as this is a great forum.
My mazda 6, 2010 2.2l diesel. The dpf light decided to rear it's ugly head, flashing away like a death knoll. But, here's the thing (as I'm sure you are aware) that light is a multi warning light for many different things.
So, plugged in the forscan, only comes up with a generic dpf fault warning. Looked further into it, and, found your advice here on how to reset. PERFECT. Worked absolutely perfectly and still not reappeared. Depressing the pedal 10 times "quickly" is the charm, and clears the dpf warning light. In my case, it seems the issue was the "oil age", that wasn't reset after the oil change by our local garage. But, annoyingly, this issue did not highlight on forscan, and, would not allow the fault code to be erased. Unless you physically do the 10 pumps on the accelerator, the fault would remain, and, on attempting the fault code clear BEFORE the 10 x accelerator pedal reset, it's no go, dpf continues to be lit, after the 10 x pedal presses its a different matter, zero fault codes.
What annoys me, (I'm am old man and get annoyed easily lol) is that forscan does not give you a warning of the oil age, only that you have a generic dpf fault. So for a lot of the mazda / Ford uninitiated out there, it's a trip to the garage and a big bill and, it's an unnecessary one as this is an easily fixable fault.
I had checked the oil, no smells of diesel in it and, oil level absolutely perfect as it always is, no loss of power, no limp mode, no rough running and even though my beasty is on 122k miles, still no smoke. So, I narrowed a few things down before making the decision to go the 10x pedal press route
Also, lastly, shop around... Should it be that you do have a genuine dpf issue, there are a few sites out there that sell cat/dpf all in one units at around £400.00.
And thank you again for this wonderful forum, without it, I too would have been looking at an undoubtedly sizeable bill.
Old Oct 1, 2025 | 08:41 AM
  #66
forscan is like giving the flight instruction manual for a Boeing 777x and expect a pilot with no training expect to learn how to fly it. Most every one that has not had basic Diagnostic training that uses a forscan gets the information wrong or mis diagnosis their vehcle. It simple information overload or not knowing how to take the basic information and interpret it correctly. You need to at least take a night school class on how to diagnose a modern OBDII and CANbus operating system before expecting to use a scan devise that unlock and gives all the information in your face! .
Based on what I have had to test on and the questions written to answer on the diagnostic I doubt anyone without some training would get 10% of the questions correct.
BTW generic DTC(s) are the indication that one or more faults are needing to be looked into to determine the anomalies or a combination of events that one in event or DTC itself may not be the cause of a problem that cause a generic DTC to be generated. This is why you look at the counters and the stored permanent DTCs.
Old Oct 1, 2025 | 08:46 AM
  #67
[QUOTE=Driventodistraction;238676][QUOTE=Eagle3561;166243
My Mazda 6, 2010 2.2l diesel. [/QUOTE]
Ogie
Apr 3, 2016 04:28 PM
Heat0188
Jun 20, 2011 03:13 PM
igsr2cool
Nov 18, 2008 02:55 PM
Jmoore284
Nov 15, 2004 10:07 PM
