Check Engine Lamp on 95 626 V6
Old Nov 12, 2005 | 11:53 AM
jerrys560's Avatar
Default Check Engine Lamp on 95 626 V6
hi. I have a 95 mazda 626 LXV6 with 182000 miles on it. Car runs like a champ but has a minor problem. Intermittantly at speeds of above 65, the check engine lamp comes on for about a mile or so and then goes out. I've noticed that if I let the car come down to 60 and then feather the gas, I can get the light off until the next time. I don't notice any changes in engine performance to correlate with the check engine lamp. I just replaced the bank 1 upstream O2 sensor and still have the same problem. Was planning a trip to South Carolina but couldn't play cat and mouse with the check engine light for 1000 miles each direction so I trashed that idea. Any suggestions?
Old Nov 12, 2005 | 10:46 PM
bkey71's Avatar
Default RE: Check Engine Lamp on 95 626 V6
You need to have the car scanned for codes to know what its trying to tell you.
A guess would be the EGR valve from what you are describing. EGR problems usuallly manifest themselves at highway speeds and are not noticeable. I would venture an EGR low flow code.
The EGR system will have carbon build up in the passages that is normal on higher mileage engines.
Funcrusher
Dec 5, 2006 10:40 PM
sin6racer
Aug 27, 2006 02:34 PM
mikeyhd
May 6, 2006 09:30 AM
itejeda
Mar 8, 2006 01:03 AM
yl3cc
Aug 24, 2005 01:39 PM
