97 626 Po441???
Old Jan 1, 2007 | 03:47 PM
froggy13's Avatar
Default 97 626 Po441???
my 626 has had the transmission rebuilt about 9 months ago and now is shifting strangely, at about 11,000 miles on it. I took it back to the transmission shop and they told me that I have an evap code and what ever caused this code is likely the problem with the shifting problems. I bought a new gas cap and replaced it, cleared the codes and now I am waiting for the PCM to run through its paces and see if the code returns. The car shifts harder than usual (sometimes) and when I am cruising at around 40-45mph at a constant speed the damn thing can't figure out which gear to be in and just shifts back and forth. Has anyone else had these kinds of issues? has anyone had any evap control problems that affected transmission performance? I have my doubts but we'll see if I've at least fixed the P0441 code. Any thoughts would be greatly appreciated.
Old Jan 1, 2007 | 05:21 PM
pickral 123's Avatar
Default RE: 97 626 Po441???
I had a millinum and believe it to have had the same trans sa your 626. It started shifting hard, sometimes, and then showed a code. Replaced the coded part and for some time it was ok. Then code came back. Did the same again and was ok for a while, and it started doing same thing yours is doing, it could'nt make up it's mind whice gear to go in. In a very short time the trans came apart completly. Nothing much inside to save. I replaced the tranny and then the car. It only had 60,000 miles on it . Not any help for you I know, but thats my story. Good luck. Jim
Old Feb 17, 2007 | 10:41 PM
mmt's Avatar
mmt
the transmission is the problem
Roy
Aug 4, 2010 07:50 AM
626v6
Apr 22, 2010 09:00 PM
blan
May 13, 2008 12:15 PM
NewGuy181
May 14, 2006 03:44 PM
doormizzles
Apr 2, 2006 09:16 PM
