94 mazda 626 crank problem
my 94 626 v6 wont start after is warm...I have already replaced spark plugs, wires, distributor, rotor, cap...i also replaced crank sensor. It all started when the car will stutter when you press on the gas...after replacing the cap and spark plug wires the problem went away but now it wont start after is warm...then i replaced distributor because i though it could be the coil, then the crank sensor, then the battery. The car will only turn on if you jump it then it runs good till you turn off the car after you run it and gets warm...if you wait a few hours or a day the car will turn on with no problem....it think it has to be some sensor but don know what kind..Please somebody give me some ideas. Thanks
plaidman
Aug 28, 2011 10:35 AM
Cataphract
Aug 26, 2008 08:10 PM
