2.0L I4 interchangable years?
Old May 23, 2006 | 03:55 PM
Larry 62694's Avatar
Default 2.0L I4 interchangable years?
Which years of engine block will interchange.
I was looking for a engine for a 94 626 and found one in a 96 probe which is 93-97 for me, and I am pretty happy with it but I could of looked for a newer lower mileage IF.................Supposedly the years are
First Generation (1979-1982) - I4, 2.0 liters, SOHC, 2bbl carb
Second Generation (1983- 1987) � I4, 2.0 liters, SOHC, 2bbl carb (1986-87: fuel injection)
Third Generation (1988-1992) - I4, 2.2 liters, SOHC, 3 valves per cylinder, fuel injection
Fourth Generation (1993-1997) - I4, 2.0 liters, DOHC, 4 valves per cylinder, fuel injection
Fifth Generation (1998-2002) - I4, 2.0 liters, DOHC, 4 valves per cylinder, fuel injection
Are the forth and fifth generations engine blocks the same or is there some external part line up issues?
can we put a fifth gen long or short block in a fourth gen car-will the tranny's bolt up?
I'm sure there must be some sensor to computor problems OBD-I vs OBD-II....but if the blocks are the same then you swap whatever sensor parts needed, MAF, EGR, IAC, TEMP etc etc
Old May 30, 2006 | 01:54 AM
d8nk's Avatar
Default RE: 2.0L I4 interchangable years?
This site might help, but even if it doesn't it is good to know about!!
Mazda Engine History CLICK HERE
arikard
Mar 13, 2013 11:36 PM
SilverProtege5
Jan 10, 2013 07:41 AM
rotal
Feb 15, 2007 09:16 PM
iowakornboy
Nov 2, 2006 12:41 AM
iowakornboy
Nov 1, 2006 06:19 PM
