Post a pic of your ride!!
Old 09-03-2009, 11:14 AM
darksideofmazda's Avatar
Default My girl...
2003 Mazda 6
2.3l
K&N Typhoon CAI/SRI
Eibach springs
Mazdaspeed exhaust
NGK Iridium plugs/wires
DVD system (mounted in the map compartment)
Attached Thumbnails Post a pic of your ride!!-0902090849.jpg   Post a pic of your ride!!-0820091530a.jpg   Post a pic of your ride!!-downsized_0813091859.jpg   Post a pic of your ride!!-downsized_0902090849a.jpg
  #102
Old 09-03-2009, 11:45 AM
nyinthabuilding05's Avatar
MODIFICATIONS:
-Custom Twin Turbo Setup
-2 Turbonetics T3 Super 60s A/R .36
-Custom mounted Spearco Intercooler
-Raptor BOV
-Custom SS 321 Piping
-NGK 6ix one step colder spark plugs gapped @ .032
-Labonte Stage 2 Water/Meth Injection Kit
-PowerMod Advanced Engine Managment System (currently the only Mazda 6 with it)
-Granatelli Motorsports Pro Series Extreme 65,000 volt Performance Ignition Coils
-Throttle Body Coolant Bypass with T-fitting delete
-Fidanza 9 lbs. Lightweight Aluminum Flywheel
-Clutchmasters FX300 Kevlar clutch
-MFactory Prototype Forged Helical LSD
-ARP Ring Gear to Differential Mounting Hardware
-Modified/Optimized EGR system modification
-Custom Performance Engineering (CP-E) Lower Transmission Mount (70 Durometer Stiffness)
-AWR Upper Transmission Mount (88 Durometer Stiffness)
-AWR Passenger Side Head Mount (88 Durometer Stiffness)
-N2MB WOT Box with 2-step and No-lift Feature
-TWM Short Throw Shifter w/bolt and hold-down modification
- Cordova Motorsports Custom Throttle Body, 60mm polished/ported/optimized w/ knife-edged throttle plate, throttle plate main shaft deleted/trimmed and remounted with countersunk screws
-Custom Lightweight Aluminum Alternator Pulley(limited run item)
-Fluidampr 10% Underdriven Crank Pulley (limited run item)
-Custom Oil Catch Can
-NRG Engine Grounding Kit
-NRG Chrome Hood Dampers(modified by me)
-custom under hood mirror inserts by unthehoodinc.com(1st and only mazda 6 with them)
-Rear hood weather stripping removal(for heat expelling)
-Ported Lower intake Manifold Runners
-O2simulator.com smart chip O2 simulator
-Battery Relocation to Trunk
Brakes and Suspension:
-Tein S-Tech Suspension
-R1 Concepts slotted and drilled rotors (front and rear)
-Axxis High Performance Ceramic Brake Pads
-Racing Beat Front Sway Bar
-AWR High Performance Adjustable Sway Bar Endlinks
-Motul RBF 600 Racing Brake Fluid (Dry Boiling Point 593 degrees F)
-Tanabe Front Strut Brace
-Megan Racing Lower Chassis H-Brace
-Techni-Fit Blue Stainless Steel Brake Line Kit
-Techni-Fit Blue Stainless Steel Clutch Line
Exterior:
-Autoexe GG-02 Front Bumper, 2-toned w/ black accenting(not sold in the states)
-Cyber Full Rear Bumper (2-toned w/ black accenting)
-Cyber Side Skirts
-Car-LED Black Housing LED conversion tail lights(one of the first imported sets)
-four way Brake-light Modification
-Mazdaspeed 6 Black Housing Headlights
-Black headlight eyelids
-Custom Flying “M” Emblems
-Mazda 6 Debadging
-Door Guard deletion
-Blue LED headlight marker lights
-Mazda CX-7 Stereo Antenna
-Aftermarket Sunroof w/ wind deflector
-Hyperwhite Headlight turn signals
-Custom Powdercoated and Airbrushed RX-8 wheels
-Powdercoated White Lugnuts - Inverted Style
Interior:
-Full Custom Interior and Uphostery, Done by Gillin Custom Design from the floor to the roof, nothing went untouched.
-Custom Steering Wheel Airbag (patented)
-Blue LED dome lights
-Sony CDX-M9900 cd/dvd/mp3 player head unit
-Sony CDX-757mx ten disk cd changer
-Kicker Solobaric L7 – 10” Subwoofer in custom ported box
-Kicker KX600.1 mono class D amplifier
-Blue LED door sill lights
-Alfa Otto Racing Reverse Glow White Gauge faces
-Custom Stainless Steel Weighted Shift **** (2 lbs)
-Custom White Accenting throughout the interior
-Custom Center arm-rest with Flying “M”
-Lotek Tri-gauge dash pod
-AEM uego wideband O2 gauge and controller
-Megan Racing Blacked out boost/vac gauge
-Megan Racing Blacked out oil pressure gauge
-Greddy Full Auto Black Turbo Timer
-Greddy Profec B Spec2 Electronic Boost Controller
Future Mods :
-Custom Chromed Valve Covers
-Forged Pistons/Rods
-Ported/Polished Heads
-Custom Sheet metal Intake manifold
-Direct Port Nitrous System
pics from august 1st, i'll post some updated ones with newer engine bay upgrades after this weekend
  #103
Old 09-08-2009, 11:03 AM
Blondee*'s Avatar
Nice Ride!!
  #104
Old 10-31-2009, 04:27 AM
85bfmr's Avatar
  #105
Old 11-03-2009, 01:18 AM
MazdaAEM's Avatar
How did you get that touch screen faceplate in your car? I thought I'd be stuck with the stock controls for everything. Does that have gps on it? How much did it cost?
  #106
Old 11-04-2009, 03:16 AM
INFAMOUS's Avatar
85bmfr that is sweet man!!! That thing must fly being so small.
  #107
Old 12-12-2009, 12:09 PM
Spiced MSP's Avatar
Default 2003 Mazdaspeed Protege
Current Mods: Corksport FMIC
Corksport Catless exhaust
Injen CAI converted to SRI
Forge BOV
AWR front and rear motor mounts 88 durometer
AWR tranny and passenger motor mount inserts
forge bov replaced with HKS SSQV on cold pipe( not pictured)
Exterior: DG Motorsports Carbon Fiber grill
DG Motorsports Carbon Fiber eyelids
Sponsor Decals from Streetunit performance(not pictured)
Mazda emblem and Protege badge painted black
Stock Racing Harts painted black
Interior: interior trim painted orange
Faze Boost gauge
Steering Column gauge pod
Greddy Full Auto Turbo Timer
Rockford Phosgate Amplifier
Pioneer 12in Subwoofer
Attached Thumbnails Post a pic of your ride!!-forum-pic.jpg   Post a pic of your ride!!-dsc04728.jpg   Post a pic of your ride!!-dsc04429.jpg   Post a pic of your ride!!-dsc04734.jpg   Post a pic of your ride!!-dsc05083.jpg
  #108
Old 12-12-2009, 08:12 PM
Me thinks I have seen these pictures and this screen name before.... ?
Are you also on 247.com? M3F.com?
  #109
Old 12-13-2009, 08:48 AM
Spiced MSP's Avatar
yeah, im on the 24/7 forum too along with 4 other forums..lol
  #110
Old 01-02-2010, 03:19 PM
niga360's Avatar
her is my all standerd 2009 HB mazda 6 check it out .....
Quick Reply: Post a pic of your ride!!
