Side Mirror Replacement guide
Old 04-15-2010, 08:22 PM
fall3n's Avatar
Default Side Mirror Replacement guide
So, today I go to my Mazda 3 2007 GS to find my driver side mirror dangling by the electrical wires. I'm wondering how easy (or hard) it is to change this mirror yourself? Has anyone here done it? If so, is there a guide online with instructions? (I've looked for something, but can't find anything). If anyone has done this before, please let me know.
Old 04-15-2010, 09:40 PM
icspots's Avatar
Do you just need to replace the glass, or the entire housing? Either way should be pretty easy. Assuming you have power mirrors then I think you'll find my heated mirror walkthrough shows how to take the mirror off and replace it pretty well.
Enjoy, and let me know if you still need some help.
http://www.mazda3forums.com/index.ph...616#msg2088616
EDIT: Since you mentioned electrical wires it seems pretty likely you have power mirrors. :P
Old 04-15-2010, 09:52 PM
fall3n's Avatar
Perfect! Thanks so much! Yes, the entire housing. It snapped as the base where the wire passes through it. I think some drunk a**hole kick it as there isn't any damage that would suggest a car hit it. I don't have heated ones, but they are power. It looks like I just need to pop off the interior panel, undo the bolts and attach the new housing. Correct?
Also, you wouldn't happen to know where I can buy a replacement mirror from or at least how to get the model number?
Old 04-15-2010, 10:10 PM
icspots's Avatar
Gotcha. Gotta hate drunk vandals.
Replacing the housing is super easy. Like you said, pop the panel, unplug, remove the bolts, swap housings and reverse to install. Easily a less than 5 minute install.
I'm not sure on the part number.... The side mirror housing was the same for the 3 from '04-'09 both hatch and sedan, with the exception in difference between manual and power glass. You should be able to contact any Mazda dealer to get the p/n and price. You could also contact Jason at onlinemazdaparts.com (mazdapart@gmail.com) or another online dealer like mazdastuff.com. I'm assuming you're in Canada, but the p/n's should be the same for all of North America. The only difference would be the color of the front cover, and if your current one is still intact then you could order whatever color you'd like and swap them out.
As to heated mirrors if you're interested in them this would be the time to do them since you have the replace the housing anyway and heated isn't that much more. An OEM heated housing costs about $100. I think the non-heated is about $75. You could also go for an aftermarket housing if you'd like. HERE's a site that sells some....... $64 without heaters, $90 with. Sad, they used to have the heated housings for $60. Anyway if you did that you could still get just a heated glass portion for the passenger side and retrofit that one.... save you ~$50.
Old 04-15-2010, 10:37 PM
fall3n's Avatar
Awesome, thanks so much for your help icspots. You've been a massive help. I'll look in to the heated mirror, but frost is not too much of an issue here in Vancouver. Though I would love to have self dimmers
Old 04-15-2010, 10:45 PM
fall3n's Avatar
I just took out the glass on the busted mirror, following your instructions (great detail btw), and notice two wires attached the mirror....I'd assume this means it is heated...I don't remember that feature when I bought it. haha. But I guess it's all automatic so I've forgotten about over the past 3 years.
Old 04-16-2010, 05:47 PM
icspots's Avatar
Thanks, glad I could help. If there are two wires plugged into the back of the glass then you do have heated glass. They come on whenever the rear defroster turns on. I actually get a lot more use out of them during rain or when they're foggy vs. actual frost. The down side of the OEM heated glass is that they're only heated around the edge and not in the center like some of the aftermarket ones are.
Beginn_er
03-08-2018 03:34 PM
pine3874
01-12-2011 06:57 PM
vlam129
02-17-2008 04:16 AM
nyghthybrid
05-31-2006 10:26 AM
fresca
03-24-2006 02:23 PM
Quick Reply: Side Mirror Replacement guide
