high idle...
Old 02-06-2010, 07:54 PM
ptt's Avatar
ptt
ptt is offline
Default high idle...
I have the 1.6L DOHC non-turbo four cylinder in my 1994 Mercury Capri and it idles at 2000rpm on cold startup. Where do I start looking? Thank you.
Old 02-06-2010, 10:11 PM
Tracker's Avatar
umm a merc on a mazda forum, well a car is a car, anyway its supposed to idle that high when its warm, now if it stays that high after the temp gauge reaches the middle THEN you have a problem
Old 02-07-2010, 03:35 PM
Lev's Avatar
Lev
Lev is offline
When I start my engine, and it's cold, it idles around 2500 and makes its way down.
Old 02-08-2010, 11:24 AM
ptt's Avatar
ptt
ptt is offline
Question Posting a mercury in this Mazda forum...
My reason for posting this vehicle is that during its production run from 1989-1994 it was powered by both the non-turbo and turbo version of the 1.6L DOHC four cylinder MAZDA engine and transmission. Mine is the 5-speed. My "problem" is that it idles at 2000 rpm on cold start and is now remaining there even after reaching normal operating temperature. I restore Chrysler Convertibles for a hobby and Im not familiar with Ford/Mazda sensor systems. I was thinking it may be a faulty coolant sensor. I can find no vacuum leaks. I have not attempted to retrieve any fault codes either. Anyone have experienced this problem with this engine? It has to be a simple fix unless it requires O2 or MAF replacement. Anyone? Thanks.
Old 02-08-2010, 08:59 PM
Tracker's Avatar
wouldnt know but it sounds like you have the protege motor, mazda and ford dont mix, so even though its a mazda built motor, it still it built with the dimensions and sensors ford makes. i can guess that it may be your maf, iat, ect, or thermostat, the o2 sensor is going to determine if your mix is lean or rich but not control your idle if its up to temp
Old 03-30-2010, 02:09 PM
ptt's Avatar
ptt
ptt is offline
Default Follow up...
Finally found the high idle problem! There were two bolts missing from the airbox that were creating a vacuum loss. New bolts...better idle (850 rpm) Thanks all for your replies.
Old 03-31-2010, 10:39 PM
Tracker's Avatar
heh its always the simple stuff
Old 03-31-2010, 10:45 PM
ptt's Avatar
ptt
ptt is offline
Yeah,
So easy to overthink sometimes! Thanks.
Fireman27
01-10-2012 02:30 PM
Milky
03-25-2009 10:21 PM
rbailey644
05-17-2006 09:54 PM
old929guy
06-12-2005 04:18 AM
carri79
06-06-2005 05:02 PM
Quick Reply: high idle...
