Demio 2004 automatic gearbox capacity???
Old 02-08-2014, 01:58 PM
jazik1's Avatar
Default Demio 2004 automatic gearbox capacity???
Does anybody know how much automatic gearbox oil have to be added after draining oil (not flushing)?
Unfortunately did not measure it when changed oil.
And now after adding less than 1.5 litre it looks as the oil level was correct.
It seems to me not right.
My Demio is 2004 and engine 1.3 petrol.
Would really appreciate any help
Old 02-08-2014, 02:47 PM
I don't know the capacity of that trans, but your owners manual should tell you... usually listed near the back of the manual.
Warm up the fluid and check it again. Chances are you didn't lose that much fluid since much of it is inside the torque converter, and the gearbox itself is rather small.
Old 02-09-2014, 08:19 AM
jazik1's Avatar
Unfortunately do not have owners manual as it was imported from Japan.
I drained the oil after driving the car so the oil was warm.
Somebody said 3 quarts (3.4 liter) but that seems too much as I have right level on oil dipstick after adding just 1.4 litre of oil.
Anybody has owners manual for automatic Demio/Mazda2?
Old 02-10-2014, 05:22 AM
You need to have the engine running to check the level.
First start it up in park & check the fluid level, if it looks ok then change it from P to D to N to R to D to N & then park.
**Check the level in park with the engine running.**
Old 02-13-2014, 04:10 AM
jazik1's Avatar
Have tried everything. The oil level is the same.
When I changed the oil it was very dark and the oil has been changed after 30k km. It was not that bad before change.
Old 02-16-2014, 10:40 AM
Be sure you are using the absolute correct fluid for the trans. It's not at all like the old says where you had two choices for tanny fluid. These days auto trans's have very specific needs. There are more priority fluids out there than ever before. Be sure to check the SAE/API specs any time you change fluids, and if they don't meet or exceed manufacturer's recommendations, don't use them.
Same goes for power steering fluids.
Other than that, I don't know what to tell you.
Old 02-19-2014, 02:19 PM
jazik1's Avatar
I use Castrol Dexron III as was told by Mazda that they are not selling transmission fluids
Old 02-20-2014, 04:51 AM
Weird, they should have their own Genuine oils, plus you should be using Mazda M-V ATF.
CX-5-2013
06-05-2013 04:20 PM
crescentpilot
11-10-2009 02:37 AM
easye1097
08-10-2006 06:22 PM
shecky
05-04-2006 10:22 PM
aircooled
10-31-2005 06:01 PM
Quick Reply: Demio 2004 automatic gearbox capacity???
