Tribute will not start after rain
Old 09-16-2009, 09:29 PM
ric325's Avatar
Default Tribute will not start after rain
I have a 6 cyl 01 Tribute that does not start after it rains. The engine turns but will not start. Eventually it will start then runs rough for several minutes. Any suggestions? Thanks for your time.
Old 09-19-2009, 02:09 AM
projexladen's Avatar
Moisture has to be getting into the system somewhere. I'd check all connectors, fuel and electrical, under the hood. Maybe something is loose and allowing some moisture inside.
Is this on cold starts only?
Old 09-19-2009, 01:23 PM
ric325's Avatar
Yes, cold starts only. I did a visual check and did not see anything obvious as far as loose connectors or something cracked.
Old 09-29-2009, 07:19 PM
Interesting. i'd take a close look at the distributor's wiring and current condition. maybe there's a crack allowing moisture inside when it rains and it's not firing plugs till enough moisture gets evaporated? I don't know if the tribute has an external coil or if it's integrated in the distributor, but i'd start again looking there
Racerrx3
04-09-2018 10:58 AM
Bobnoxious
12-25-2015 09:15 AM
chineseknife
03-12-2009 05:25 PM
tribute owner
06-03-2008 10:27 AM
NewToMazda
11-26-2006 10:13 PM
Quick Reply: Tribute will not start after rain
