brake and ABS light stays on
Old 04-12-2014, 09:35 AM
Ken Knowles's Avatar
Default brake and ABS light stays on
The ABS and brake light on the dash board stays on. I don't notice any different with stopping. the front brake pads are only a year old and looks good. what would cause both ABS and brake light to come on?
Old 04-13-2014, 07:31 AM
Check your brake lights, check your brake fluid, get a diagnostic code check of the ABS system.
Old 04-17-2014, 03:30 PM
can I get the abs codes off the machine at autozone?
Old 04-18-2014, 04:23 AM
No idea on autozone. Different country to Me.
Old 04-20-2014, 05:48 PM
ok, so I changed all the pads, and the front rotors. I found a broken toner ring for the ABS on the front drivers side axle. I replaced that, and the sensor. The abs and brake light are still on. How do I reset this? I tried the disconnect the battery trick. It lights up as soon as I turn the key over. it does not seem "scan" for anything.
Old 04-21-2014, 07:47 AM
Did you get a code check?
schlompie
03-06-2012 02:49 PM
thinhbui
11-19-2009 12:13 PM
kyroguy
03-11-2009 10:39 PM
gchood
11-13-2007 06:43 PM
Quick Reply: brake and ABS light stays on
