cabin filter(pollen filter)
Old 10-16-2007, 06:06 AM
andy936867's Avatar
Default cabin filter(pollen filter)
hi, guys, how often do you chnage the cabin filter for the air con? mine is nearly 5 years old and may be this is the time.
Old 10-16-2007, 07:57 AM
TomV1's Avatar
Default RE: cabin filter(pollen filter)
I check this out once a year, I have replaced it twice in the 4 years I have owned mine.
Old 10-16-2007, 03:17 PM
Where exactly is the cabin Filter ?
Old 10-18-2007, 04:18 AM
andy936867's Avatar
it is the filter for the air coming to the cabin I think, from the aircon. mazda charge me $160AU, cheap?
Old 10-18-2007, 07:15 AM
TomV1's Avatar
Autozone sells them for about $25 US.
Old 10-18-2007, 09:05 AM
Here's an old post from Babyhuey
Replacement is not difficult at all Lucy02. The cabin air filter is located under the right side half of the cowling just in front of the windshield. Start by turning on the wipers and then shutting the key off when wipers are are vertical. this will give you access to one of the screws to be removed. You will notice that just below the windshield there are 8 little round plastic covers in the cowling. With the hood down, remove the four covers on the right side and then the four phillips screws under these plastic covers. Now open the hood and remove the plastic clips attaching the plastic cowling to the sheet metal. The entire right side of the cowling can now be removed. Under this will be a loose plastic cover piece. Remove this as well and you will then be able to see the fresh air opening for the ventilation system. Cabin air filter will fit right inside that rectangle area with the grid in the middle.
Just as an FYI. The Tribute does not come with a cabin air filter iinstalled from the factory but is an option to be installed later.
Thumbnail Image
These are the 4 little plastic covers and phillips screws that need removed with hood down.
Thumbnail Image
With hood open remove these four plastic clips and remove right half of cowling.
Thumbnail Image
The black plastic piece here is not secured and is there to keep water from getting into fresh air intake duct. Pull it straight out towards from of vehicle.
Thumbnail Image
Here is finally the cabin air filter. Older style filters have a rubber seal around outside and newer one do not.
Attachment (4)
< Message edited by babyhuey -- 6/4/2007 2:19:35 PM >
Old 10-20-2007, 04:10 AM
andy936867's Avatar
that is a great help. but I do not know why it is so dear in australia, the Au dollor is 0.9 something, and 60 au is around 55US$, that is a big difference.
Mozart
06-18-2018 02:21 PM
potatowithahaton
04-08-2010 09:40 AM
mrki_tua
11-13-2007 09:50 AM
g_kang2002
10-31-2007 04:20 AM
ashko
08-08-2007 08:27 PM
Quick Reply: cabin filter(pollen filter)
