Whats the difference???
Old 06-19-2006, 07:52 PM
Thor_k06's Avatar
Default Whats the difference???
Hey all im wondering whats the difference between a turbo rx7 engine and the non turbo??? are they both build differently... ( the engine only)... like does the turbo engine have more wirings and plugs and do i have to do more adjustments to it... do u think its going to be hard putting in a turbo engine into the non turbo engine??? well if you can answer this please write back thanx...
Old 06-20-2006, 01:24 AM
87 turbo II's Avatar
Default RE: Whats the difference???
There's alot of differences between the turbo and non turbo engine and even more between the turbo and non turbo car.
Engine-
Turbo------------------------------Non-turbo
low compression rotors--------high compression rotors
4 ports---------------------------6 ports
turbo charger-------------------no turbocharger
top mounted intercooler--------no intercooler
different ECU--------------------differnet ECU(from turbo engine)
different wiring harness---------diff. wiring harness (from turbo engine)
car-
stiffer transmission---------------weaker transmission
wider diameter driveshaft-------longer thinner driveshaft
stronger half-shafts--------------weaker half shaftas
limited slip differential-----------open differential
2.5" diameter exhaust pipes----1.5" diameter exhaust pipes
16 x 7 inch wheels---------------14 x 5 or 15x 6 inch wheels depending on model
larger brake discs----------------smaller brake discs
better calipers--------------------weaker calipers
stiffer suspension----------------more comfortable but less responsive suspension (GXL has AAS)
aerodynamic mirrors(body clr)----black standard mirrors
aluminum hood w/ scoop---------steel flat hood
rear spoiler-------------------------no spoiler
twill weave interrior---------------cheaper cloth interrior
stiff racey buckets-----------------buckets w/ less support
160mph/ speedometer-----------140mp/h s[eedometer
boost guage------------------------voltometer
and some standard feature on the turbo that are options on non turbo Rx-7s (GXL shares the features)
-sunroof
-rear wiper
-plush carpeting
-rear storage bins
-power windows
-power mirrors
The Turbo has so much more to offer even if you exclude the luxerious features, making a non turbo Rx-7 perform like a turbo requires much more than just changing the engine (this requires new ECU, New wiring harness, new exhaust, and the turbo hood. This is assuming you buy the longblock turbo engine to put in, otherwise you would need more) you'd still want the transmission and rear end setup with Limited slip and such. It is much better to buy a turbo Rx-7 than to try and convert to one.
QuickerinSilver
06-21-2007 08:40 PM
mikeyp
12-22-2006 03:53 AM
k
12-01-2006 10:16 PM
sinista
08-23-2005 01:00 AM
Quick Reply: Whats the difference???
