transmission mounts
Old 11-24-2005, 03:34 AM
fcmazda's Avatar
Default transmission mounts
What might I expect to pay to have a transmission mount replaced on my '99 Mazda Protege (part/labor)?
I understand it is not as tough as replacing a motor mount, but how long should it take my shop to replace?
Thanks!
Old 11-27-2005, 12:20 AM
babyhuey's Avatar
Default RE: transmission mounts
Which mount are you looking at having replaced? Is it the one on left side under air cleaner housing? Up front by the radiator, or rear back by the firewall? What engine size as well? Auto or manual trans? Can get you price and part number with above info as well as estimate for time.
Old 11-28-2005, 02:39 PM
fcmazda's Avatar
The transmission mount is rear back by the firewall.
Mazda Protege ES, 1.8-liter 4-cylinder, manual 5-speed.
Thanks!
Old 11-28-2005, 06:33 PM
babyhuey's Avatar
Take a look at your vehicle build date located on the drivers b-pillar. Should be on a sticker just below your door striker. There are two different mounts depending on when was built. If built between 12/01/1998 and 04/15/1999 then you need a Mazda part #B25D-39-040C that retails for $83.05. Available from onlinemazdaparts for $66.44. If built after 04/15/1999 then will need Mazda part #BJ0N-39-040C that retails for $49.80. $42.33 from online.
Labor listed in Mitchell is 1.1 hrs for trans mount. Dollar amount will depend on labor rate that your shop charges.
Old 11-28-2005, 09:11 PM
fcmazda's Avatar
Thank you! I appreciate the info very much!
liz4jim
08-05-2011 01:04 PM
jswilson64
03-04-2008 03:46 PM
germanshepherd
07-26-2007 10:14 PM
wsoape281
03-03-2007 04:30 PM
wkhoury
04-13-2006 02:53 PM
Quick Reply: transmission mounts
