before i spend a lot of money
I have a 92 protege 1.8 and it is burning oil like no ones business. I think its the valve guide seals. I need some advice or ideas before i get those and that is not what it is. Thanks
Remove the spark plugs. connect a compression gauge and write down the readings. Squirt maybe a tablespoon of oil into the cylinders and run the compression test again. If little or no change in readings the rings should be ok. If there is a significant difference then it will need rings.
