02 Protege5 Makes terrible squealing from belt when heater fan is turned on
Old 12-12-2009, 07:03 PM
blitzez420's Avatar
Default 02 Protege5 Makes terrible squealing from belt when heater fan is turned on
I have an 02 Protege5 that makes a terrible squealing noise when started up in the cold and engaged the clutch. Or when driving and I turn on the heat. I tried popping the hood and feeling the belts right after its squealing and none feel hot. Any ideas?
Old 12-12-2009, 08:19 PM
Slippage due to additional current draw. Replace the belt(s,) w/new of course, and a proper torquing, clean the pulley's, That should solve the problem.
Old 01-01-2010, 05:38 PM
jbj's Avatar
jbj
jbj is offline
Default mine does the same thing
My 2000 Protoge 1.6 does the same thing. I replaced the alternator belt and tightened it but can't get the noise to go away. The belt doesn't show any signs of slipage wear. Could it be something else? It makes so much noise that I can't tell where it is coming from. Frustrated.
Old 01-02-2010, 12:13 AM
wsoape281's Avatar
most likely, the pulleys are dirty. when a belt starts to slip, it leaves bits of rubber and debris behind. i always recommend going over the pulleys with a wire brush before re-installing the belt.
the other possibility is that the shaft on the water pump is bent.
mcoday
11-12-2012 04:26 AM
Cramm557
12-01-2010 03:44 PM
the_nood
06-22-2009 07:03 PM
zoom1640
05-03-2007 03:02 PM
jdempsey57
06-12-2005 04:02 AM
Quick Reply: 02 Protege5 Makes terrible squealing from belt when heater fan is turned on
