Hesitating and missing
Old 12-01-2016, 11:31 PM
junkyarddog's Avatar
Smile Hesitating and missing
Hi 1998 Mazda B4000 4.0 I bought this truck and it would hesitate at times and miss around 2000 rpms on street or hi-way. Checked Pc, Iac, Egr, Tpc, Maf sensors, and all were working. This issue did not have a error code. I found that I had a Ground problem ( Low Voltage at the fuel pump ) After cleaning the grounds (next to dr side kick panel behind the cover There is a ground connection ) also the Fuel pump connection under the truck (using electrical cleaner) So far I have not experienced any more problems. PLEASE CHECK THE SIMPLE THINS FIRST DIRTY OR BAD OR LOOSE CONNECTIONS B-4 GOING OUT AND SPEND A LOT OF MONEY. IHope this helped some of you that may be having similar problems.
Old 12-02-2016, 06:56 AM
Cusser's Avatar
Go to a Ford Ranger forum, that's really what your truck is.
I'd change spark plugs, air cleaner, fuel filter, start with that. Clean all your electrical connections too.
chaser
07-01-2009 05:26 PM
delmad
01-20-2009 08:03 AM
PcBrEaK05
07-10-2007 03:00 PM
icedillon
07-22-2006 08:38 AM
chaznw
07-29-2005 02:01 AM
Quick Reply: Hesitating and missing
