Hesitating and missing
Old Dec 1, 2016 | 11:31 PM
junkyarddog's Avatar
Smile Hesitating and missing
Hi 1998 Mazda B4000 4.0 I bought this truck and it would hesitate at times and miss around 2000 rpms on street or hi-way. Checked Pc, Iac, Egr, Tpc, Maf sensors, and all were working. This issue did not have a error code. I found that I had a Ground problem ( Low Voltage at the fuel pump ) After cleaning the grounds (next to dr side kick panel behind the cover There is a ground connection ) also the Fuel pump connection under the truck (using electrical cleaner) So far I have not experienced any more problems. PLEASE CHECK THE SIMPLE THINS FIRST DIRTY OR BAD OR LOOSE CONNECTIONS B-4 GOING OUT AND SPEND A LOT OF MONEY. IHope this helped some of you that may be having similar problems.
Old Dec 2, 2016 | 06:56 AM
Cusser's Avatar
Go to a Ford Ranger forum, that's really what your truck is.
I'd change spark plugs, air cleaner, fuel filter, start with that. Clean all your electrical connections too.
chaser
Jul 1, 2009 05:26 PM
delmad
Jan 20, 2009 08:03 AM
PcBrEaK05
Jul 10, 2007 03:00 PM
icedillon
Jul 22, 2006 08:38 AM
chaznw
Jul 29, 2005 02:01 AM
