Engine Idle Specs need help, Idel RPM, Idle Vacuum, Timin, Spark plug gap??? basics needed
Old 08-10-2006, 12:59 AM
xtrigger's Avatar
Default Engine Idle Specs need help, Idel RPM, Idle Vacuum, Timin, Spark plug gap??? basics needed
Engine Idle Specs like the, Idel RPM, Idle Vacuum, Timin, Spark plug gap, all the basic stock setting to have engine run right...mine runs a bit rough.....ill replace wires, plugs and clean all conectors if that dont help ill have to play with timin or what ever ideas you guys might have
Old 08-10-2006, 09:32 AM
mazdab2600's Avatar
Default RE: Engine Idle Specs need help, Idel RPM, Idle Vacuum, Timin, Spark plug gap??? basics needed
from your other post's its a 2600
need year
need transmission auto/manual
Old 08-10-2006, 01:05 PM
xtrigger's Avatar
B2600i 4x4 5spd 2.6L 1992
Old 08-10-2006, 02:42 PM
mazdab2600's Avatar
here's some info
Old 08-10-2006, 07:02 PM
xtrigger's Avatar
okey thanks...i got access to Michall on Demand so im able to find more info that i might need...and btw truck idles good now.........i adjusted the timin (dist cap movin around) and played with idle screw...truck runs alot better
lisarae
05-27-2007 08:56 PM
Am4wag
02-08-2007 11:38 PM
pnyklr
02-07-2007 10:31 PM
lukeinva
09-23-2005 10:42 PM
woburnmazda
09-01-2005 05:44 PM
Quick Reply: Engine Idle Specs need help, Idel RPM, Idle Vacuum, Timin, Spark plug gap??? basics needed
