98 b4000 no start
Old 09-08-2007, 04:54 PM
seppy's Avatar
Default 98 b4000 no start
my 98 b4000 will not start sometimes, it turns over with lots of power. i put a new fuel pump in recently. but it has no spark at the coil pack. when i get a push start it will fire up and run fine. this no start problem is intermitten. most times it will start right up. someone told me about the cam sensor?? does anyone have any info for me?? thanks in advance.
Old 09-09-2007, 01:09 PM
hixx's Avatar
Default RE: 98 b4000 no start
Any codes? Cam sensor/crank sensor would be my first tests.
Old 09-17-2007, 08:01 PM
seppy's Avatar
thanks for the reply hixx; i put on a new cam sensor, but a day later it is doing the same thing. intermitten no start. but as soon as i push start the truck it fires up right away. and it will usually be good for the rest of the day. it seems i wont start first thing in the morning. any other ideas? i am going to change the crank sensor; would you know where it is located?? its a 98 mazda B4000 4.0 L V6 5spd.
thanks again.
Old 09-18-2007, 06:17 PM
hixx's Avatar
It should be at the bottom front of the engine at the crank pulley. Are there no pending codes in the PCM?
Old 09-19-2007, 06:09 PM
seppy's Avatar
i checked with a snap-on scanner and it is showing no codes.
Old 09-21-2007, 05:59 PM
seppy's Avatar
i put in a new crank sensor and that was the problem. thanks again
plowman2000
02-21-2009 12:33 AM
michaelm
08-22-2008 01:22 PM
el cheffe
05-06-2008 01:55 AM
def328
03-11-2006 11:30 AM
Tom73
11-18-2005 04:44 PM
Quick Reply: 98 b4000 no start
