93 2600 fan / a/c problem
Old 05-23-2007, 01:08 PM
wazzuup_34's Avatar
Default 93 2600 fan / a/c problem
1993 B2600i with a/c.
Out of nowhere my fan quit working on 1 and 2. The fan will work on 3 and 4.
the a/c will only come on when in 1 or 2. Which is where the blower don't work. When you go to 3 or 4 the blower comes on and the a/c kicks off. Any ideas?
Thanks.
Old 05-24-2007, 01:27 PM
Cusser's Avatar
Default RE: 93 2600 fan / a/c problem
This is likely related to the blower resistors located on the outside of the evaporator case under the dashboard, passenger side.
Old 05-24-2007, 06:41 PM
Default As Long As We're On the Subject...
On my B2600i, the fan works okay, but the AC compressor won't come on when I push the AC button on the dash. It WILL come on when it gets 12V via a jumper wire to the battery. Fuse is okay so I figure the relay might be the next thing to check. Anyone know where that might be located?
Thanks much.
Old 05-25-2007, 10:00 PM
Cusser's Avatar
Default RE: As Long As We're On the Subject...
Actually, I'd check out that switch itself. It pulls out toward the rear. When I bought my B2200in '94 it was working intermittantly, and I had to clean it out. My question is (at night, when it can be seen): does the light in the switch come on when you push it in? It should, if it's working.
Old 06-13-2007, 07:35 AM
wazzuup_34's Avatar
Yes! The light comes on but only on speeds one or two where the fan don't work ( and you can hear the compressor clicking on.) When you go to 3 or 4 speeds the light goes off, compressor clicks off and blower comes on.
Old 06-13-2007, 10:59 PM
rolomac's Avatar
Location: Northern California (FAR Northern California)
coincidentally there is a heater/fan switch up for auction on Ebay right now. It's item number 220121299553 and therewere no bids on it when I looked at it just minutes ago. It's from a '91 B2600i and I don't know about fitting your '93 but it's worth looking at. Minimum bid is $24 or so and they want $12 shipping (rip off).
Rolomac
Old 06-14-2007, 08:27 AM
wazzuup_34's Avatar
Ebay may be the place. Dealer wants $75 for the fan switch and $45 for the resistor.
Old 06-15-2007, 07:46 PM
get on mazdatruckin.com and ask DAN ADKINS he should be able to find you one for a decent price
kallgrer
07-19-2007 12:32 AM
2600duude
06-18-2007 11:51 PM
sunsetmazdacs
01-29-2007 07:14 PM
reddogracing
04-03-2005 08:41 PM
Quick Reply: 93 2600 fan / a/c problem
