89 b2200 cranks but no start.
Old 09-17-2012, 03:20 PM
XxStirCrazedxX's Avatar
Default 89 b2200 cranks but no start.
tryed searching but could find anything that helped.
It cranks over but wont start, has fuel and spark. tryed staring fluid and nothing. checked timing belt and its good. seemed like a good strong spark so am really confused
Old 09-17-2012, 07:52 PM
MazdaTirol's Avatar
It is possible your spark plugs are so wet with fuel that there is no spark at them and/or the cylinder walls have been washed down with gas and you now have very very low compression, if you wanted you can always remove them, clean and dry them, crank over engine a few times without plugs to "dry" the cylinders a bit, squirt a little bit of oil in each cylinder then re-install the plugs and try again.
rlCWFXKM
08-20-2020 08:07 AM
IslandMighty
05-05-2010 03:55 PM
jrc
03-17-2009 06:56 AM
chadm_88
08-04-2008 02:54 PM
ansonone
03-27-2008 09:07 PM
Quick Reply: 89 b2200 cranks but no start.
