Problems with my Mx3
Old 04-09-2007, 06:24 PM
Mx3soccer's Avatar
Default Problems with my Mx3
My car will start cold no problem, but will idel high around 2,000 to 2,500. After running for a while, whenever i shift into nuteral to brake, the engine dies and i have to hold down thegas to get it running again, and it takes a good while to do so. I replaced the spark plugs, the wires, the rotar, the distributer and the fuel pump. Does any one know what might be wrong?
Old 04-09-2007, 07:19 PM
Mx3soccer's Avatar
Default RE: Problems with my Mx3
Also, whenI goover 10mph and shift into 2nd, the gear grinds, and no other gear does that. When parked, or going under 10mph, it shifts smoothly. Any suggestions?
Old 04-09-2007, 10:41 PM
babyhuey's Avatar
What year is the MX-3 and does it have the 4 cyl or V6?
Is it only idling at 200-2500 after cold start and then once it is warmed up will not idle at all?
Old 04-11-2007, 12:18 AM
Mx3soccer's Avatar
It's a 95 with a 4 cyl. It runs high no matter what.
Old 01-05-2008, 02:04 AM
im having similar problems with my 93 mx3 im not throwing any codes but a mechanic friend says its probably a vaccum leak
Old 01-08-2008, 07:08 PM
It's defenetly either a vaccume leak but it can easily be a compression problem, if you have a mechanic friend get him or her to check the compression for you. It's pretty inexpensive if you take it to a garage but watch out of people trying to rip you off. GOOD LUCK!
LeClaire7
10-29-2011 10:55 AM
rexlepeno
12-31-2008 07:25 PM
etcaires
07-04-2007 02:00 PM
thakid22
08-26-2005 05:16 PM
Guests
04-25-2004 12:35 AM
Quick Reply: Problems with my Mx3
