Adding Manual Tranny Fluid???? Help
I have a 1992 MX-3 and cannot find the plug for checking the manual tranny fluid level and adding fluid ..... I drianed the old fluid to change a half axel but the refill/level check plug is not where chilton's says it should be and the speedometer cabel connection is too low...... anybody got any ideas (or pictures)?
Thanks, Mike
Thanks, Mike
RE: Adding Manual Tranny Fluid???? Help
yes you do have to fill the fluid up through the speedo sensor. if you look at the sensor right above the gear there is a kinda of step (looks like an L shape) this is the fluid level full mark. fill it through the speedo sensor hole & insert the sensor & remove it kinda like a dipstick.
By chance, did you happen to see how old thatOP is? [sm=smiley2.gif]
Two posts in three years. I don't think he's waiting for an answer any longer.
