93 MX6 Clutch sticking and sinking
Old 12-13-2007, 03:31 PM
JanMan77's Avatar
Default 93 MX6 Clutch sticking and sinking
I have had my mx6 for about 3 months now. A few weeks ago the pedal startedto squeak. Then just about 3 or 4 days ago the pedal would stick when it was fully pressed.I had to start pulling it back up with my foot, then it would work just fine. I then sprayed greaseup onto the return spring. Yesterday the pedal stuck but was a lot harder to pull back. When ever I put it in gear (with the clutch pushed in) the clutch catches and kills the car within 2 seconds..but the clutch is still pushed down. When i am driving..after i shift and let go of the clutch, and pull it back out with my foot..the pedal starts to sink back to the floor. once the pedal is back to the floor it still acts as if the clutch is not pushed down. I have checked the master cylinder but there is no leaking anywhere. Where should i look and what should i test? should i actually pull the master cylinder and inspect it? thanks
Old 03-05-2008, 05:00 PM
Default RE: 93 MX6 Clutch sticking and sinking
didyou bleed the cluch
Old 03-06-2008, 07:04 PM
Check Your clutch slave Cylinder my 1st gen 6 was doing that a few months ago andI left me stuck at a light andI had it changed out on my lunch it really easy on the 1st gen am not so sure about a 93 though but the piece was only like 28-29 dollars but let me know if you figured it out.... -Joey
MutantGenepool
01-11-2016 07:47 AM
dave87
06-05-2007 09:54 AM
vinylgroove
09-29-2006 07:23 PM
matchboxcarz
11-12-2005 05:59 AM
DougD
05-31-2005 12:55 AM
Quick Reply: 93 MX6 Clutch sticking and sinking
