2000 MPV Trouble code P0421
Old 06-20-2009, 02:04 PM
thelordparadox's Avatar
Default 2000 MPV Trouble code P0421
Autozone's analysis on my MPV's Check Engine Light says "Warm-up catalyst system (RH) efficiency below threshold".
What does that mean?
Old 06-20-2009, 04:58 PM
NightSwimmer's Avatar
It means that the pre-cat that is hardest to reach (at the firewall) is operating at less than perfect efficiency. The downstream Oxygen sensor is active because of unburned fuel residue passing through the converter unconverted. It is a rather expensive repair -- even with aftermarket parts.
Other issues could be involved. If you have a leak in your exhaust manifold you can get this error even if your catalyst is good.
808mazdampv
04-08-2011 03:18 PM
NightSwimmer
03-18-2009 06:42 PM
maddflavor
05-22-2008 04:51 PM
jroberts 312
02-27-2006 05:23 PM
prostarthunder
04-09-2005 04:37 PM
Quick Reply: 2000 MPV Trouble code P0421
