Brake fluid in power steering pump..OOPS!!!
Old 09-12-2004, 01:07 PM
jr70895's Avatar
Default Brake fluid in power steering pump..OOPS!!!
Someone by accident poured a small can full of brake fluid in my power steering pump. My question is will it cause any damage, and if so how can I get it out. Do I need to take the return hose off and drain it. A local parts store told me that it will swell up the seals and make it start leaking. Thanks for any additional info.
Old 02-03-2005, 01:01 PM
Default RE: Brake fluid in power steering pump..OOPS!!!
DEF. REPLACE THE FLUID WITH POWERSTEERING FLUID-DO THIS FLSH AT LEAST A COUPLE TIMES BEFORE YOU DRIVE -THIS SHOULD BE OK BUT IF YOU LEAVE IT IN YES -YOUR POWER STEERING RACK AND PUMP WILL REQUIRE REPLACEMENT
Genesys
12-22-2020 04:58 PM
ZDP
11-29-2014 09:09 PM
GreenLX2001
11-21-2012 09:19 PM
yustr
11-08-2012 04:46 PM
matthewc
07-02-2007 09:20 PM
Quick Reply: Brake fluid in power steering pump..OOPS!!!
