Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
lifting the b2600
Old Mar 14, 2012 | 05:29 PM
trainwrecker's Avatar
Question lifting the b2600
If anyone needs pointed in the right direction or needs tips lifting the b2600 let me know and I will let you know what can be done on a budget.
Old May 3, 2012 | 03:53 AM
ellerdustin's Avatar
I would love to know how I can lift my 1987 B2600 4x4 without doing a body lift. Any info will be appreciated thanks
Old May 15, 2012 | 07:24 PM
First take the weightoff the front end and turn the tortion bars up I went 10 turns. Now pay attention not to go to far. Turn them up a few then set it down. Now what u should watch is your down travel bump stops. When under full weight I have 3/4 inch gap. If u top them out the ride will be rough and could risk braking a bar. For the back get a helper spring. Separate the spring pack from the axle. Take the overload spring off and flip it upside down cause they are usually bent. Then put the helper between the overload and spring pack. You will need a longer spring center bolt and vise grips to compress the pack. The original bolt worked fine for me. I gained 2 1/2 in in the front and 3 1/2 in the back Plus with being able to fit 32x11.50x 15. Mud tires it is a full 5 inches taller. Hope this helps. P.s. this should only take 1 to 2 hrs with basic tools. Check mine out one hear
capo
Mar 15, 2010 01:12 AM
watsongs
Jun 8, 2006 09:20 PM
ABTireman
Jun 3, 2005 03:09 AM
Stephanie1968
May 5, 2005 02:31 PM
migwelder01
Jul 4, 2004 08:06 AM
