Front drivers side ticking sound
Also
also wanted to add that when i had the front raised and was turning the tire by hand, i would turn the tire about an inch forward and then the same amount backward and i did hear a click and felt A little resistance. The sound was coming from where the CV shaft went into the transmission.
Update today
Just a quick update. I have not changed the CV yet. I rolled up the drivers side window while driving today, and rolled down the passenger side window. I could hear the ticking on that side as well. Also, the ticking noise is there weather I am going straight or turning either direction. Could it be something to do with my transmission? What could I check to narrow down this issue? Please, any suggestions would be appreciated. Thanks
Anybody
anybody here. Only 1 day off this week. I was looking forward to at least 1 response. Oh well. Probably try another forum.
Another update
So I raised the front end and removed the tire on the passengers side to do some inspecting. Right away I noticed the boot on the CV shaft was split wide open! That must be the problem, or so I thought. I replaced the CV shaft or i think it may be called the half shaft, then I put everything back together( kind of) and took her out for a spin. She was still ticking. Ticks when I am going straight, or tuning either direction. Sound remains the same, unless I am going in reverse then there us no ticking. When I was working on the CV, I did notice that the seal on the front sway bar link where it connects to the strut is torn. I will be replacing that as soon as I get a dremel to cut off the nut that I stripped. I also stripped the inner hex fitting on the bolt as well. :mad: I also stripped one of the built in bolts of my strut bearing plate. :mad:On driving on 2 bolts instead of 3 in my bearing plate. Is that dangerous? What a day. Still don't know what ticking noise is. Feeling frustrated and angry. Please help.
