2008 cx9
Old 11-07-2014, 09:27 AM
melmonta's Avatar
Default 2008 cx9
A/C issue - A/C turns on when I turn off the vehicle
HAs anyone had this issue and how did they fix it
Old 11-07-2014, 10:58 AM
hixx's Avatar
A/C compressor turns on? or the blower motor turns on?
Old 12-06-2014, 05:33 PM
melmonta's Avatar
Default new fuses fixed the issue
Old 09-08-2016, 05:00 PM
melmonta's Avatar
it is now 2 years later and I have once again replaced the blower motor relays and the front vents do not blow any air, I am getting great ventilation from the rear vents.
any suggestions or help is greatly appreciated. In south Florida you need the a/c all year
Old 01-26-2017, 12:53 AM
fishport's Avatar
Hi melmonta, did you fix the Front vents not blowing air?
Old 05-15-2017, 04:25 PM
JuanDelgado6478's Avatar
Hi Melmonta: In regards to Blower on when engine off; Same problem here, what fuses or what relay did you change? Please send me your comments. Thanks in advance.
Old 01-03-2018, 05:02 PM
bluenote53's Avatar
Wasn't this something that was an issue in a recall? I had this problem with my 2008 CX-9 and took it in for the recall and they replaced the relay.
Old 01-03-2018, 05:35 PM
Hi Bluenote53; this is a old issue; I found the relays in the fuses box, engine compartment; this is a Relay failure; you can find the relays for $25-$30 usd Dealer Parts or Auto Shop Store for $10-$15 usd. I just check the position of the terminals of the new relay versus my relay; I change both Front and Rear Fan Relays; problem fixed since a year ago. I hope this helps. Happy New Year!
Old 01-04-2018, 04:13 AM
Known fault with CX-9's.
Replace both Blower Motor Relays.
Part #L1Y1-67-730
mjj078
02-25-2014 08:09 AM
jandt
12-05-2013 06:44 PM
Herblenny
01-14-2008 08:53 AM
flino4
12-18-2007 03:17 PM
john k
05-09-2007 10:06 PM
Quick Reply: 2008 cx9
