Popping sound from engine
Hi guys,
I'm new to this forum and I surfed all the internet searching solution to my issue. I recently bought a Mazda BHALP 2 door car made in 1999. After few days I found a leak in power steering horse and replaced it. After replacing power steering hose, oil start to leak from the power steering rack. I replaced that also. Now there is a new issue which I can not find a solution. When I slightly turn the steering wheel there is a popping noise coming underneath air cooler. Not from the air cooler. I think it is coming from power steering rack. Also power steering hose shakes while I do the turning. I doubt when hose replacing they might have put the spring in to the wrong direction inside of the horse. |
Run thru the basics first. Rack mounting bolts and the steering shaft to the rack. If the pop wasn't there before you worked on it........
