New Motor
Good evening. Anyone have any suggestions where to get a new/used motor for a 2005 RX8 shinka? Im In the Tampa, FL area. Will any Rx 8 motor fit the shinka model? It’s an automatic. I’m told the engine is bad due to low compression. I know this has been a known issue with these cars. Has anyone else experienced this and what avenues did you take? Does Mazda stand behind this issue or is it better to scrap it? Thanks |
Take it to Mazda for a compression test, you can't use a conventional compression tester on a rotary. Depending on the results of the compression test, you can "hydro clean" the engine to remove carbon build up on the apex seals.
(Post 170923)
