vehicle system malfunction
Old May 21, 2024 | 07:39 AM
Emir's Avatar
Exclamation vehicle system malfunction
Hello,
I know this is a common issue with this Mazda model, but I still can't find a specific answer on this topic. Therefore, I am asking if anyone has dealt with this warning (vehicle system malfunction) and how they resolved it? Thank you
Old May 22, 2024 | 07:15 AM
Has it been scanned for fault codes?
If not, then get it scanned.
This is a generic warning, covering potentially hundreds of fault codes.
Old May 23, 2024 | 12:00 AM
Emir's Avatar
"Hello, it was scanned at two different services, but neither could determine the cause of the problem."
Old May 25, 2024 | 06:22 AM
What fault codes were logged?
Old May 27, 2024 | 01:47 AM
Emir's Avatar
Hello,
These errors are being displayed, but there don't seem to be any issues. The engine is running fine, and no actual problems are noticeable despite these errors.
Best regards.
Old May 29, 2024 | 07:48 AM
Vacuum pump failure on the diesel engine is common. There was a recall on the SH engine covering the vacuum pump on certain vehicles.
Old Sep 27, 2024 | 01:46 AM
gadas's Avatar
Has someone figured out?
Old Sep 27, 2024 | 01:20 PM
Mazdaon's Avatar
Vehicle System Malfunction it's a generic advisory warning, It could be anything, you need to scan for error codes. OP seems to ignore errors after scanning car. These errors trigger VSM. 1- Vacuum pump out of range is a very common issue on diesel cars. The other DTC is trivial, FOB battery is depleted, but if is not taking care can produce an immobilize code or theft detected warning. So scan your car and address issues.
Old Sep 27, 2024 | 03:37 PM
Unless the OP returns and more Q&A then NO to your question!
Look at the last time the OP has posted on this forum?
Old Sep 27, 2024 | 03:42 PM
I would say the same to you. Look at when the OP last posted and likely came back here to this thread?
And until more Q&A all it is is guessing and you would be better off using and asking the 8 ball for the answers.
Mravan
Aug 4, 2024 06:16 PM
andreyco
Jul 14, 2021 08:59 AM
Merc
May 4, 2021 11:32 AM
Veginwels
Useless Post
Aug 4, 2015 11:18 AM
Zoot1
Jun 26, 2012 10:43 PM
