Transmission Bolts Part Number?
Old Sep 15, 2025 | 06:12 AM
r1racer1's Avatar
Default Transmission Bolts Part Number?
I'm getting ready to drop the pan and change the oil filter on my kid's 2016 AT Mazda 6. Does anyone know the part number to pan bolts (not the drain plug)? Thanks.
Old Sep 15, 2025 | 12:11 PM
Take a bolt to a local hardware store look in the stainless steel section and match up the bolt. Cheaper and better quality then OEM
OH and most hardware store have a thread gauge to use.
Old Sep 16, 2025 | 06:43 PM
There is no need to replace the M6 bolts. Just give the a good clean to remove any sealant.
Old Sep 18, 2025 | 08:00 AM
r1racer1's Avatar
OK good to know.
Old Sep 18, 2025 | 08:01 AM
r1racer1's Avatar
I only need 5 quarts for the pan drop correct? Would I be safe just adding what I take out or do I need to break out the OBD II and check the trans temp?
Old Sep 18, 2025 | 08:18 AM
No always check using the dipstick and with the transmission warm .
Old Sep 21, 2025 | 04:55 PM
r1racer1's Avatar
How many quarts do I need 5 or 6?
Old Sep 21, 2025 | 08:13 PM
Have at least 5 on hand. Cant say as I or we in the shop ever needing 6 on a pan and filter change on a Skyactiv transmission , ever?
Old Sep 27, 2025 | 11:39 AM
r1racer1's Avatar
What's the learning procedure for the transmission or can I skip that part?
Old Sep 27, 2025 | 12:35 PM
For a simple drain pan and filter service it's not required. Actually, even with a full transmission service its not needed either so you are good to go! .
