starting problem
Old May 12, 2011 | 12:44 PM
djdiamond's Avatar
Default starting problem
I have a 2005 mazda 6 which inconsistently wont start. theres a lil light on instrument panel of a car with a key inside it. does this tie together? all fuses are in place and are good. it has plenty of battery judging the lights, radio, etc. but when it is running i remove negative from battery and car dies instantly. anyway the altenator signal is affecting my cranking problems or is this a seperate problem?
Old May 12, 2011 | 01:02 PM
djdiamond's Avatar
also when i try the key its like no response just a lil click from under dash, when it doesnt start. my first step will be to see the meaning of the light. no car manual
Old May 12, 2011 | 01:57 PM
AHan's Avatar
Sounds like the battery to me. Is it the original battery? You can not tell a thing by the lights operating. It could also be the starter, but my money is on the battery.
I think the key symbol is the immobilizer. It should go out with the key in the ignition. If it isn't going out, and the car won't start, you may need to have the key reprogrammed. A weak battery could activiate the immobilizer as well.
Old May 12, 2011 | 08:29 PM
djdiamond's Avatar
ok and the light does stay on even when it cranks the light still blinkin. it is not the original batt and is that light tied in to the security for the car or the remote? what about reprogramming the remote for the alarm? when i dont use the remote or alarm and just lok the doors it seems to crank like normal.
ControlG
Jan 15, 2007 10:51 AM
GRHoward1937
Nov 2, 2006 12:16 AM
Tbird
Aug 25, 2006 02:50 PM
bar17
May 17, 2006 10:56 PM
sabanab35
Aug 29, 2005 07:59 AM
