replacing the headlight bulbs in 2011 Mazda6!!!!
I love this car. I've had it for three years and NEVER had a single problem, despite driving the heck out of it and beating it up on nasty New Mexico roads. (110K miles in 3.5 years). I follow manufacturer's maintenance and service recommendations religiously.
However, I think I've run into my first issue, albeit a minor one. I have a burned out drivers side low-beam headlight bulb. And changing it is impossible if one does not have the hands of a three year old. The dealer wants $200 to change both low-beam bulbs. That's just for labor. He says the front fascia and other things have to be removed and/or moved to access the tight fit. That seems ridiculous, but then again, every car has a design issue. I think I found mine. My brother in law thinks he can do it. I think not! I have two new OEM low-beam bulbs from the dealer parts dept...is this something I can do easily, with regular tools, or is it incredibly involved and I need to pony up the cash and have it done right? Any help would be appreciated. First time on the forum, and with two Mazdas, I know I'll be logging in here often. Thanks. |
Labor time is less than half an hour. Maybe try another repair shop.
Originally Posted by hixx
(Post 152221)
I had a hell of time with my 2006. Small skinny hands does help! |
I have not done one. Just looked up the labor time on Alldata. It pays .4 for one bulb and .7 for both.
wow. Wish I read this before. I just bought a HID lights kit to replace the low beam headlights myself. I thought I could do it. Now I'm having second thought.
Oh well, I'll find out. |
This is what it say's in the workshop Manual.
Halogen Type Low-beam 1. Disconnect the negative battery cable. 2. Remove the fasteners and slightly bend back the mudguard. 3. Disconnect the connector. ===================================== I can't remember changing a bulb in this model. Maybe its like the CX-7 & you reach up thru the wheel arch after peeling back the plastic guard liner. Otherwise its pretty easy to remove the bumper & then the headlight. All you need is a Phillips screwdriver, 8mm & 10mm socket, smallish flat blade screwdriver. |
got it done. Removed part of the mudguard (as suggested above) and did it through the wheel wells. A royal pain without a lift but it got done.
Thanks. |
Originally Posted by kpl1228
(Post 152262)
Thanks. https://farm9.staticflickr.com/8755/...63da287c_z.jpg https://farm9.staticflickr.com/8804/...b5303903_z.jpg https://farm8.staticflickr.com/7713/...de628103_z.jpg https://farm9.staticflickr.com/8771/...b913dc73_z.jpg https://farm8.staticflickr.com/7632/...9f16c91f_z.jpg I did the backup light too, replaced with LED. https://farm8.staticflickr.com/7615/...381b0985_z.jpg |
Originally Posted by Koki
(Post 152307)
I only had to move the fuse box a little to the left on the2015 Mazda 6 and was able to sneak my hands through and got the HID install. I'm not a handy kind of guy so I sort of did a half fast job with the install. I used XenonDepot's H11 Xtreme HID kit with German Philips 4300K bulbs.
However, originally removed bumper assy to install HID's, as passenger side not as accessible. http://i1049.photobucket.com/albums/...e/SAM_2162.jpg http://i1049.photobucket.com/albums/...e/HiD_Pass.jpg |
so I removed part of the mudguard to get it done, but now I need to replace several of those body clips/screws that hold the mudguard on. Totally busted them up.
Is there an official parts number or part description for those clips for the Mazda6? I need to order them online because I'm in the boonies and nowhere near a Mazda dealer. And I'd like OEM parts. Thanks all. I'm having a tough time finding the right part online for some reason. |
