P2262 main problem code
Old Nov 7, 2020 | 12:00 PM
Mikeli's Avatar
Default P2262 main problem code
hello sorry for my English.
I have a problem with my mazda 6 2.2 skayD 110kw.
the turbo is not working.but when i start the engine and go in 1st and accelerate switch 2nd in higher rpm the turbo is workung normal but when the rpms go back the car turns off the turbo.
checket and cleaned the MAP sensor, MAF also wacuum pipes checket they are ok.
the main problem code is p2262 the second is p0471
Help me
Old Nov 7, 2020 | 11:09 PM
P0471 is super common, the Exhaust Pressure sensors fail alot. Mazda in my country added a warranty extension for this reason.
P2262 is also a well known fault. 1st step is to remove the intake & outlet pipes/hoses to the turbo & make sure both the small & big turbo turbines spin freely & the wastegates are intact. There was a bad batch of wastegates that would break the rivet holding the valve to the arm.
Old Nov 8, 2020 | 01:10 AM
Mikeli's Avatar
Thank you!
for the sensor fault it is clear to change it.
the fault p2262 you mean to check the actuator on the botton of the turbo?
i dodnt understand you sorry
Old Nov 8, 2020 | 01:35 AM
Not the actuators, but both the turbine blades and physical wastegates.
Old Nov 8, 2020 | 04:15 AM
Mikeli's Avatar
I checked them, they are ok. Strange is that last week i had that code and then few days went with no codes the car deletet the lamp alone and then yesterday again lamp and p2262
Old Mar 9, 2021 | 01:19 AM
David Cureton's Avatar
Default Same issue for me
Hi, I had exactly the same codes on my 2017 2.2D skyactiv CX-5. Accompanied by check engine light and a loss of power.
Armed with the knowledge that it was most likely the exhaust gas pressure sensor I took it to the Mazda dealer. Upon picking up my car the servcie guy said that Mazda Australia had extended the warrany on the exhaust pressure sensor to 10 years/200000kms so the repairs on my car were under warranty without cost.
The repair work was to replace the exhaust pressure sensor that sits on the top of the engine under the noise shield. It was not a like-for-like replacement but with another unit that does not exhibit the same failure mechanism... i hope.
Just wanted to give back to with this information so others can find it as I did when I had this issue.
Old Apr 14, 2021 | 12:25 PM
Krupezza's Avatar
Hi!
David, you wrote your dealer replaced sensor for free.
Im from Belarus. I have Mazda 6 2.2 D. This car came to Belarus from Germany. I am the second owner here. And now I have the same problem, but belarussian dealer told me, that this sensor in my Mazda was replaced in Germany alredy. Car has 145000 kms.....
Old Apr 15, 2021 | 03:48 AM
If the sensor is black & or plastic, its the older type. If its silver/chrome in colour and solid steel then its the latest supersession.
Old Apr 16, 2021 | 07:06 AM
Krupezza's Avatar
I think I solved the problem. I removed sensor, washed it by carburetor cleaner, dried up and installed back. Error disapeared by itself.
Than I traveled in different modes around 5-6km: from calm to aggressive. Everything is fine at present time.
Old May 16, 2021 | 09:04 AM
DanLamont's Avatar
Default Help
I have same error code today, where is the sensor located as I’d like to try cleaning it too
