Oil/Grease Leak
Old Mar 13, 2008 | 11:53 AM
roberto811's Avatar
Default Oil/Grease Leak
I noticed the look of shiny grease on the bottom of my car so I took the bottom cover off and discovered this. It looks like it is coming from the place circled in the picture. If you know what this part or any advice would be appreciated.
Old Mar 14, 2008 | 09:23 AM
Mazmart Trini's Avatar
Default RE: Oil/Grease Leak
The part in the picture is your passenger side sway bar bracket. Usually it is greased from the factory, but not to where you would get what you are seeing. It looks as if the leak (oil not grease) is coming from elsewhere & just accumulating at the point.
Old Mar 20, 2008 | 09:31 AM
davidteachey's Avatar
Mazmart is exactly correct. That bracket is not the source of your leak. If you raise the car and put a work light underneath, perhaps you'll find the source. Good luck...you'll find it!
David
Jessev
Aug 6, 2021 10:03 AM
Rpalmigiano
Dec 24, 2012 12:21 PM
JJohnsonAZ
Apr 9, 2011 07:18 PM
kallgrer
Mar 26, 2007 07:23 PM
vegasvic
Jul 31, 2005 03:24 PM
