MAZDASPEED6 ECU
Old Jan 21, 2007 | 10:25 PM
EB233HWT's Avatar
Default MAZDASPEED6 ECU
Does anyone know if there are ne chips out there for the speed6. Already have a boost reg in it, along with a blowoff valve, just gettin started with mods, but i can only push it to 20lbs of boost safely without a chip. Lemme know what you guys got.
Thanks...
Old Jan 22, 2007 | 02:59 AM
JBix's Avatar
Default RE: MAZDASPEED6 ECU
I hope you're not putting out 20 psi with the stock turbo, it's no good past 17 max. I wouldn't push it past the stock 15. I believe cpe is working on a tuner they are close to finishing, but I don't know if anybody has a tuner yet. I assume you're referring to something like hypertech or superchips that you plug in to the obd II port?
Old Jan 23, 2007 | 07:32 PM
EB233HWT's Avatar
I would think you can push the stock turbo wayy more than 17, it puts out like 15.6 stock.... but im not too sure.....but yeah thanks for the info
Old Jan 24, 2007 | 05:43 PM
MrTea's Avatar
the speed uses a rather small turbo, so once you get in the 17psi range you start to overload it. this turbo is typically used on 1.8L vw's. you can look up the graphs if you want, it's called a "K04" though the exact variant isn't known. sorry to burst your bubble.
Old Jan 26, 2007 | 06:26 AM
JBix's Avatar
Once you're over 17PSI, you're just pumping EXTREMELY hot air into the engine, raising the chances of detonation and actually probably lowering power. The comp would probably cut fuel cause the air is too hot.
Old Jan 27, 2007 | 01:24 AM
EB233HWT's Avatar
thanks for the info guys, just so i make sure 17 is a safe amount, or nething below 17?
Old Jan 27, 2007 | 11:04 AM
MrTea's Avatar
if you setup a mbc to hold boost at say 15/16psi, you will still feel a "huge" gain in most cases. most "tuners" tend to drive their car close to redling when have fun before shifting. in the speed, your last 1700rpm....sucks. using a boost controller to hold boost all the way to redline will keep that feeling at least a bit longer into redline, so the car feels as many do...peaking pretty high up, not in the middle of the band.
at 17 you can still experience fuel cut as it borders the MAF's high point, so you might wanna stick to 16psi if you don't want that feeling from time to time.
gmag211
Apr 16, 2010 02:43 PM
morecowbell
Aug 19, 2007 02:15 AM
bsprogs
Aug 11, 2006 05:22 AM
the_gray_mazda6
Mar 23, 2006 05:27 PM
ATL
Mar 6, 2006 12:08 AM
