mazda side moldings///adhesive or ported holes?
Old Feb 20, 2009 | 11:05 PM
zpalumbo1's Avatar
Post mazda side moldings///adhesive or ported holes?
hey guys. i hd a question bout the side moldings bout mid way on the door. are they just really stuck on or are they drilled into to door. by that i mean snapped in with holes in the doors.
Thanks
Zach
Old Feb 21, 2009 | 12:28 AM
rx4to6's Avatar
They are glued.
Old Feb 21, 2009 | 12:31 PM
CKeffer's Avatar
Glued isn't really the proper term. They are held on with a strong double sided tape. To remove them you'll need a hair dryer or heat gun, a credit card or something similar to help pry up the molding without damaging the car, and a rag & some goo gone (i hear WD40 works too) to remove whatever residue is left over.
-Cameron Keffer
Old Jun 12, 2009 | 07:56 PM
Zgirbeata's Avatar
I hear dental floss or fishing line works well to get the molding off. As far as getting double sided tape off, good luck. Just know that it will take a long time. Sometimes you'll get lucky with heat to some type of solvent but usually no.
Old Jun 13, 2009 | 11:10 AM
CKeffer's Avatar
Huh, mine took all of 15 - 20 minutes to get rid of all 4. Also the tape can be rubbed off then any residue can be removed by using goo gone or something similar. Though the fishing line or dental floss will work just fine, I found the plastic card easier because it gives you some leverage to work with.
-Cameron Keffer
ruissar
Jul 19, 2011 01:55 PM
kct
May 28, 2010 03:59 PM
ginia
Apr 16, 2010 06:09 PM
Mark56
Dec 21, 2009 09:29 PM
kimnremi97
Aug 30, 2005 03:24 AM
